Das am Hut ist breites Satinband mit einer schmale Posamentenborte drüber
wunderschön sieht das aus
Ich sollte häufiger 2 Wochen im Urlaub verschwinden. Du bist ja schon fast fertig! und es sieht toll aus. Jetzt bin ich mal auf ein Bild mit menschlichem Inhalt (also von Dir) gespannt. ![]()
Alles anzeigen46. Trim remaining piece of flat eyelet trim along a decorative inner edge to archieve desired look to trim outer edge of collar. Pin the piece of tear away stabilizer to wrong side of collar. With right sides face up , pin eyelet to collar, with outer scalloped edge even with outer curved edge of collar. Use a very narrow zig-zag stitch over inner cut edge of eyelet. Tear away stabilizer. trim garment fabric away from under eyelet very close to stitching, being careful not to cut eyelet. Press.
47. Double fold nias tape comes prefolded, with one side slightly wider than the other. Use the wider side of the tape on the right side of the fabric. To preshape tape to the curve of the collar neck edge, with a steam iron strech the double fold edge and press. Prepare bias tape for collar bands as follows : Open out wider edge of double fold bias tape.
48. Narrow hem ends of collar , pressing under 5/8" (1,5cm). With right sides together, pin tape to neck edge of collar having crease 5/8" (1,5cm) from raw edge, having tape extend 5/8" (1,5cm) beyond opening edges, as shown . Stitch in 5/8" (1,5cm) seam. Trim seam; clip curves. Press tape out , pressing seam toward tape. Turn in ends of tape, turning tape to wrong side along single folded edge. On inside, slip-stitch tape to collar.
49. With wrong side of collar up, sew knob side of seven snaps to bias tape, sewing on at each end, one in the center and two evently spaced between ends and center back , as shown.
50. Center and pin collar to neck edge, having collar bias tape on wrong side of bodice. Mark neck edge of vodice at each snap. Sew socket side of snaps to each mark on bodice neck edge. Snap collar band to inside of garment, turning collar out. Steam collar lightly if necessary.
Aber sicher gibt es noch Tragefotos .....
Kann mir keiner von euch bei der Übersetzung der Kragenverarbeitung helfen ? Ich bin mir nicht sicher wie das gemeint ist.
Ich habe jetzt den Batistkragen mit selbstklebendem Stickvlies verstärkt und mal die Spitze drauf gesteckt. Ich würde das jetzt so machen , das ich die Seiten mit engem Zickzack versäubere und an der inneren Naht die Spitze auf den Batist nähe. Dann die innere Naht mit Schrägband einfassen und den Batist knappkantig wieder entfernen. Zum Schluß dann die Druckknöpfe annähen. Ich gehe jetzt einfach mal davon aus das der Batist nur als Vorlage für die Rundung dienen soll ........sicher bin ich mir da nicht.
Sooooo , langsam komme ich in den Endspurt ![]()
Für den Kragen habe ich den Batist mit selbstklebendem Stickvlies ( anderes geht sicher auch ) verstärkt. Dann die Spitze so aufgesteckt das die untere Rundung passt und oben eingekräuselt .
( Foto siehe oben )
Die Seiten mit Zickzack versäubert und die obere Rundung aufgesteppt. Dann eine Seite des Schrägbandes angenäht und den Batist vorsichtig wieder entfernt. Danach die zweite Seite des Schrägbandes von Hand angenäht.
7 Druckknöpfe angenäht.
Die Gegenstücke an die Taille genäht und den Kragen angeknöpft.
Das ist wunderschön geworden ![]()
So, das Taillenband muß ich jetzt noch annähen und an den Markierungen kommen die BustPads hin . Ich hoffe danach schieben sich die oberen Haken nicht mehr auf , sonst muß ich 1-2 Druckknöpfe dazwischen setzen. Woher nu die Falte im Rücken kommt ? Keine Ahnung , vielleicht weil ich das Taillenband an den Abnähern noch mit Stecknadeln fixiert habe. Wenn die Falte bleibt .....ist mir ehrlich gesagt dann auch wurscht .....
Bust-pads?? wir dda ein Busen hingeschummelt? Vielleicht sollte ich das bei einigen meiner Blusen mal ausprobieren, die da notorisch zu viel Stoff haben??? ![]()
Falten im Rücken: Bisserl runterziehen? In der Taille (oder drunter) zu knapp??? Vielleicht vom Korsett?
Das Kleid scheint 'groß' zu machen. Also die Figur zu strecken. Ich tu mich gerade wahnsinnig schwer Deine Körper-Größe anhand der Bilder zu schätzen. Ich bin bei 1.8?m bezüglich Schätzwert.
Alles anzeigenBust-pads?? wir dda ein Busen hingeschummelt? Vielleicht sollte ich das bei einigen meiner Blusen mal ausprobieren, die da notorisch zu viel Stoff haben???
ui , na da muß ich mich aber noch was strecken
ich bin nur 1,68cm groß ....bzw. klein.
Und diese BustPads werden hoffentlich die Falten im Vorderteil etwas begrenzen .( Die kommen nicht mal ansatzweise in die Nähe des Busens ;)) Zum Armloch hin ist ja doch schon noch reichlich Stoff vorhanden.
Mal schauen wie es dann bei mir aussieht .......wenig Busen hab ich ja von Natur aus schon nicht ......aber evtl. sitzt das Kleid dann noch einen Ticken besser.
Nach nochmaligem anschauen des Fotos könnte die Falte im Rücken auch davon kommen das ich irgendwie schief stehe , bzw. das Oberteil verrutscht ist.
*schmacht*, was sieht das getragen schön aus...
Also so 'kurz' wie ich. Einen Ticken länger bist Du noch...
Rückenfalten: hmmm... sieht eigentlich gerade stehend aus, eher etwas nach vorne geneigt. Das sollte eher Zugfalten in die andere Richtung geben, wenn schon Falten... hmmm... ich würde da jetzt aber noch nicht in Panik ausbrechen sondern noch mindestens ein weiteres Mal das Teil sorgfältig neu anziehen und noch einmal testen... das ist doch alles so miteinander verschnürt, das kann eigentlich gar nicht verrutschen. Zur Not: Am Korsett festtackern (Knöpfe, Bändchen/Schlaufen...) ![]()
Hohlkreuz vielleicht? Aber das ist ja auch nicht Dein erstes körpernahes Kleid. Wenn da was wäre, wüßtest Du das und hättest es sicher schon beim Probestück beachtet... nochmal probieren. Ganz eindeutig.
Nachtrag: DANKE. Beim zurückblättern ist mir gerade aufgegangen, wie das mit den auswechselbaren Kragen funktioniert...
also ich hoffe es gefällt euch ? Ich glaube mittlerwile fast wirklich das die Falte daran liegt das das Taillenband noch nicht fest ist . In der Anleitung steht ja , frei übersetzt : Das Taillenband sollte gut mit getragenem Oberteil abgemessen werden , da es dafür sorgt das die Taille nicht verrutscht und dort bleibt wo sie hingehört.
Und naja ich denke ein leichtes Hohlkreuz habe ich evtl. aber ein wenig Bewegungszugabe kann auch nicht schaden
Wir werden es sehen wenn alles fertig ist und jemand anderer die Fotos macht .
Was denkt ihr wie dick diese Polyesterwatte für die BustPads sein sollte ? Ich finde nur die Angabe über die Größe :0,4m x 1,15m
Jepp, getragen sieht das noch mal so schön aus ![]()
Wofür denn danke ? Falls du noch Fragen hast immer raus damit . Dafür mach ich doch den WIP.
Ich habe mir neulich bei einem ganz anderen Projekt Gedanken darüber gemacht, wie die Dinger realisiert werden/sein könnten und wie man das früher gemacht hat.. so vor 50 Jahren oder so, als es so etwas noch gab... Der Umschlag nach innen scheint mir vor allem ein wichtiger Punkt. Die Knöpfe sind dann eher zusätzliche Sicherheit. Nichts was Du wissen konntest, als Du das da oben gepostet hast
Aber kam zeitlich genau passend für mich ![]()
mmh , die Knöpfe sind jetzt nicht nur zur Sicherheit, sondern der Kragen ist damit am Oberteil befestigt.
Der Kragen liegt also quasi links auf links auf dem Oberteil , ist nach oben gerichtet und wird dann über den Ausschnitt nach unten geklappt.
Falls du willst, mach ich noch ein Detailfoto von der Befestigung.
Hast Du inzwischen das Problem mit dem Reifrock gelöst?
Ja , den hab ich jetzt schon verstärkt und die Bänder oben anders festgemacht . Jetzt scheint es zu halten . Aber den muß ich nochmal "verschönern" ich hab jetzt einfach alles "quick and dirty" gemacht und die Schlitze die ich reinschneiden mußte mit Panzerband zugeklebt .......die Bänder oben sind auch noch alle offen sichtbar. Da muß ich nochmal ran . Wenn es wieder "schick" aussieht mach ich ein Foto
Hier noch ein Bild der geänderten Krinoline .
Bei den Kreuzchen ist ein zweiter Stahlring reingekommen.
Die Bänder hab ich jetzt mittig auf dem Gürtel befestigt und mit Schrägband abgedeckt.
Das hier sind die Schnittteile für die BustPads.
Alle drei werden übereinander genäht und dann mit Stoff überzogen .
Ich muß sagen das sieht echt riesig aus. Ich bin gespannt wie es eingenäht wirkt.
Ich hab' da mal 'ne Frage zum Reifrock: Ist es notwendig, den 2. Ring zu schließen???
